Air Bag Warning Light
RE: Air Bag Warning Light
mine does this too, I took out the air bag to find out one of the wires on the connector was cut, I just disconnected the plug, as I have heard it may go off if you dont know what youre doing.
It should just flash a specific number of times, unlike the check engine light which flashes a series of numbers to indicate fault codes. One note on unplugging the air bag system, it does have a back up battery power supply so if you don't disconnect that as well you will still get the flashes on the light, and the system will still be active. Just something to watch out for....
mine bliks 6 times( i think) it doesnt have a fuse in it and im scared to put one in it but do you know what 6 times means? lol is there anyway to just disconnect it all and make the lught go off or what?
This drives me crazy. I don't notice any sequence to the blinking-it blinks continous until I shut off the engine. Does this mean there is a problem in the air bag system or is this just a pesky little light. Again if I shut off the engine and start it back the light may not blink.
Does anyone know if the sytem would still function in a crash?? or if the thing is going to blow out at anytime..I just noticed this recently. How long has your light been blinking?
