Problem with ignition switch
Old Mar 14, 2009 | 05:44 PM
barney50's Avatar
barney50
Default Problem with ignition switch
I have a 90 Foxbody and in order for the turn signals to work or heat to blow I have to start it then turn the key back a tad until they come on, and when you go down the road sometimes before I can use the turn signas I have to turn it back a tad again. It has a brand new key and cylinder. What would cause this?
Old Mar 14, 2009 | 06:03 PM
Compression's Avatar
Compression
It sounds like the contacts in your ignition switch are starting to wear out causing your ignition and acc voltage to drop out. The problem is in your ignition switch.
2007CalSpec
Dec 13, 2020 11:42 AM
Granatelli Sales
Mar 25, 2016 08:01 PM
Granatelli Sales
Dec 27, 2015 06:28 PM
zanemoseley
Sep 6, 2015 12:58 PM
whatsup62
Sep 3, 2015 01:38 PM
