Trying to remove control arms Help!
I'm trying to remove my rear control arms. I was able to remove the axle side of the bottom rear control arm and pull the spring out. But I can not remove the engine side bolts on the lower control arm. I tried to use a 3/4 and 19mm socket, but they both twist around the bolt when trying to use the ratchet. I tried mutliple sizes but none fit like 3/4 and 19mm. They are the only socket that will fit snug by hand. but like I mentioned when using the ratchet they just do not grab the bolt or nut. Does anyone have any suggestions?
When i did mine i dont think i had any issues with the bolts, but if you are going to replace the bushings it was a pain to get the old ones out. I found the best way to go about it was using a hole saw and drilling the rubber bushings then taking a hammer to the sleeves made it pretty simple GL
