want to build an 11 second 5.0
Old Mar 17, 2009 | 04:15 PM
cdan03's Avatar
cdan03
Default want to build an 11 second 5.0
hey this is my first post over here, i am interested in buying a 5.0 mustang. It will have high miles on it. I would like to make it an 11 second car. What should i do to achieve a reliable 11 second car? Thanks in advance!
Old Mar 17, 2009 | 04:22 PM
bernout's Avatar
bernout
You are going to need alot of stuff..
Either a full engine build or a supercharger/turbo kit and alot of praying.. haha
A top end kit (Heads, Cam, Intakes, Throttle body, injectors, fuel pump) and those types of things will get you pretty quick if you have the supporting suspension but I think you'll need to build a block or get a power adder to get in the 11's.
Old Mar 17, 2009 | 04:45 PM
Portmaster's Avatar
Portmaster
347 Stroker kit (10.1+)
AFR 185 or Trick Flow 185 heads (or new 190 Fast as cast)
Comp Cams XE282HR cam
Holley HP Street750 double pumper
Edelbrock RPM air gap port matched and opened up just a little.
1.75 Longtube headers
Good ignition system
Supporting engine parts
4:10 gears
Subframe connectors
beefed up torque boxs
Drag radials
Good driver
Presto, youre in the 11's
Old Mar 17, 2009 | 04:48 PM
95greengt's Avatar
95greengt
4:10 gears
Subframe connectors
Drag radials
Good driver
you make it sound so easy.... lol
Old Mar 17, 2009 | 05:00 PM
Portmaster's Avatar
Portmaster
It is you just have to pay to play.
Old Mar 17, 2009 | 05:01 PM
BlessedHellride's Avatar
BlessedHellride
Pro Comp 190cc heads, out the box
Comp Cams XFI 236HR cam
Holley 750 Vacuum Sec, out the box
Full MSD ignition system
3.90 gears
Subframe connectors
Drag radials
Good driver
Presto, I went into 11's
I re-wrote some things Portmaster, but that's my engine in a nut shell. I ran into the 11's with that set up, shifting at 5850rpms.
Old Mar 17, 2009 | 05:05 PM
BlessedHellride
Not to mention the money it cost me to build this car.
Old Mar 17, 2009 | 05:07 PM
Portmaster's Avatar
Portmaster
Throw a Comp 288 street solid roller cam and a set of AFR 205 heads and port matched Victor Jr and you'll be in the 10's but better get some block insurance, lol
Old Mar 17, 2009 | 05:14 PM
BlessedHellride
I'd let a large "black" man do foul things to me for a set of AFR 205's. If I could go back to the beginning of my engine build up, I would have bought a set of AFR 205's. Didn't really know as much about them back then as I do now. I see now that you can take the 205's and still upgrade in displacement and be OK. Hind sight is 20/20
Slo5oh's Avatar
Slo5oh
Banned
I think hes talking about things that are equivilant to praying.
