will not rev past 3k
i have read all these post and i have never got a real solution. here is my problem....the car ran fine then all of the sudden it started running like crap. it will not go above 3k. i can hold the pedal to the floor and it garbles and backfires. but it runs fine till i get to the 3k mark.but it will rev up fine in park. i did a fuel pressure test and i seems fine.(sits at 35-40) i has new plugs and wires. new cap and rotor,fuel filter,tps,throttlebody, egr valve.mass air..i tryed to run codes but when i hooked it up to the plug under the hood the code reader wont work...please give me your two cents..could it be the computer.its stock
Mine is doing something similar...about 3500. My fuel pressure is at 32 until I rev it up and then it drops to 28. When I let off it wil go up a little above 32. When I unhook the vacuum it goes to 40 at Idle. I'm also thinking the ignition module may be taking a digger?
Have you changed yours yet? Mine is also not throwing any codes??
I did test the coil and it is just a little low on the secondary resistance.
