Still vibrating, frustrated
06-15-2005, 11:05 PM
Well, changed the harmonic balancer and front rotors, still got a vibration.
The vibration happens at about 37mph and 47mph, and last for a second then smoothes out.
95 Mustang GT aode, could it be driveshaft or gears ?
06-15-2005, 11:26 PM
RE: Still vibrating, frustrated
Did you have the wheels balanced and the front end aligned recently?
06-15-2005, 11:30 PM
Yes, I had an alignment and wheels balanced twice. I was there for the second balancing so I could view it myself.
06-15-2005, 11:35 PM
You sure the problem is in the front?
You may want to try rotating the tires to eliminate them as the problem. One could have a problem but also still be in balance.
06-16-2005, 12:02 AM
maybe your wheel is bent? I had a similar problem in my explorer and it turned out to be the tires
06-16-2005, 12:43 PM
driveshaft u-joints
06-16-2005, 04:12 PM
Quote:
ORIGINAL: ryanm1986
mtgldr
02-03-2024 09:00 PM
4cylinderplus2
10-09-2020 07:45 PM
baddog671
07-26-2016 01:20 PM
mdj89
09-23-2015 08:49 AM
03blackwidow
09-20-2015 02:36 PM
