stalling at idel
Old 03-24-2009, 05:37 PM
tyler08
tyler08's Avatar
Default stalling at idel
ok I recently installed mas unequal shorties an off road h pipe and flowmaster catback. MY car is stalling frequently at idel. I did not delete the smog system I just disconnected the hose and removed the metal tube that went to the factory cats. I checked my tps voltage output with the key on engine off and it is 1.5 volts, do I have a bad tps? What else should I check. Bad iac? Thanks
tyler08 is offline
Old 03-25-2009, 10:18 AM
Jaked4e
Jaked4e's Avatar
what year is the car is it S/D
Jaked4e is offline
Old 03-25-2009, 04:19 PM
87foxgt
87foxgt's Avatar
I would try cleaning or buy a new IAC , but how was your car idling before you did upgrades
87foxgt is offline
Old 03-25-2009, 07:17 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
did the problem occur after the mods you did??
mjr46 is offline
Old 03-25-2009, 10:22 PM
tyler08
tyler08's Avatar
its an 87 gt...sd. It was having occasional stalling at idel issues last fall before I put it up for the winter, but its much more frequent now after the exhaust swap. I deff. notice it more when smog pump is running but it is never quite ideling perfect at the moment. I am going to remove the smog system when I have a little free time to spend on the car. Is it normal for the voltage output on my tps to be as high as 1.5 volts at idel? Thanks again for all your guys help!! I will try cleaning the throttle body and iac and see if this helps.
tyler08 is offline
Old 03-26-2009, 04:29 AM
89Mustangn00b
89Mustangn00b's Avatar
does the car stop stalling once its warmed up? Could just be your timing is set too low. My 89 GT will instantly stall unless I rev it a little until it's warmed up.
89Mustangn00b is offline
Old 03-26-2009, 09:11 PM
tyler08
tyler08's Avatar
ok so I took off the iac and ran about a half can of carb cleaner thru it, there was a lot of crude in there.. The car does idel better, but it still stalls right after starting if I dont give a quick blip of throttle, then it is fine afterward untill next time I shut off the engine and restart.
tyler08 is offline
Old 03-26-2009, 09:25 PM
mjr46
mjr46's Avatar
check the fuel pressure and see if it holds in koeo mode and if it's fine, try a good seafoam treatment......carbon acts as a sponge and may soak up the fuel charge on initial start up and lean it out enough to cause a stall.
mjr46 is offline
Old 03-26-2009, 09:36 PM
tyler08
tyler08's Avatar
the fuel pressure does hold with koeo. I'll try the foambath and see what happens. thanks for your help with all my posts as of lately.
tyler08 is offline
Old 03-26-2009, 09:41 PM
mjr46
mjr46's Avatar
no problem, also make sure you have no vaccum leaks
mjr46 is offline
Quick Reply: stalling at idel
