set timing, need help
Old Mar 25, 2009 | 03:18 PM
9165pt0's Avatar
9165pt0
Originally Posted by Nav50
When you take it out you are basically setting a "rough timing". The spout connector basically lets the computer take over the timing. You can "fine tune" the timing once you have the "rough timing" set. Same principle but you have the spout in. You only want to go a slight few degrees with it in though. You don't want to go moving it like 5 or more. Under 4 should be ok.
^ so whats the deal with the fine tuning?
Old Mar 25, 2009 | 04:52 PM
AdderMk2's Avatar
AdderMk2
Banned
you dont
fine tuning is done with a chip, and a programer
neither of which, you have
Old Mar 25, 2009 | 04:58 PM
minnow81469's Avatar
minnow81469
uhh thats not him on his period thats him naturally u learn to deal with it lol
Old Mar 25, 2009 | 06:21 PM
9165pt0's Avatar
9165pt0
lol its kool. hes helped me out a bunch of times, and has done the same for damn near everyone on here. but i still think a lil GFE will help him out lol.
ima set the timing tonight and ill post an update.
Old Mar 25, 2009 | 09:43 PM
9165pt0's Avatar
9165pt0
ok so i went and checked what my timings at. with the spout out it reads btwn 0-5 degrees? runs strong and feels much better than it used to. i set it to 12 degrees and it pings. set it back and it runs strong. it reads about 15 degrees with spout in. wtf? how can it run so good with the timing so low.
Old Mar 25, 2009 | 09:49 PM
AdderMk2's Avatar
AdderMk2
Banned
ignore the reading you are getting with the spout in... i told you this before
when you remove the spout connector you are removing the ECM's ability to control timing by itself. when you re-install it, the car is making the proper adjustments based on running conditions... which is why I told you to set it/forget it/stfu before
if you are pinging at 12°... then its very likely that you balancer is shot... replace it and reset timing again
Old Mar 25, 2009 | 10:04 PM
OnyxCobra's Avatar
OnyxCobra
this still sounds like ur doing it wrong. It should be set to 12 BTC with the spout OUT, not 0-5. With the spout in it will read differently than you set it at.
Old Mar 25, 2009 | 10:11 PM
9165pt0's Avatar
9165pt0
yah i know adder, i was just stating it to make it clear where the timing was at. i think your right about the balancer might be shot. theres no way its really at 5 degrees and running that good.
Old Mar 25, 2009 | 10:15 PM
9165pt0's Avatar
9165pt0
i took out the spout, started car, checked timing. it reads at 0-5 and sounds weak like its idling lower. but with the spout in it runs great.
i set base timing to 12 degrees with spout out and it sounded good, put spout back in and it pings like crazy.
so i think adder hit it on the spot, its probabley the balancer.
Old Mar 26, 2009 | 01:04 PM
KJMac's Avatar
KJMac
Originally Posted by AdderMk2
take the spout out, set 12-14° timing..
after that you are done... put the spout back in and dont worry about what the comuter does
its smarter than you are.. trust me
I tried to det the timing on my 1995 GT and I can't find the matk an the damper or what to use on the timing pointer?
My book doesn't show it!
Is it the edge of the long pointer sticking out?
