I now know why I have a vacuum leak... With PICS!
Old Mar 31, 2009 | 03:48 PM
KINGKAOS's Avatar
KINGKAOS
Question I now know why I have a vacuum leak... With PICS!
I found 2 loose hoses. I hooked 1 up n I was told 2 cap the other 1 off.. Since it goes 2 the smog. Which isn't hooked up.. When I did so the car will not start.. N when it does start it stalls right out! I un-capped that 1 hose and tried 2 start it. N it did the same thing.. I unplugged the other 1.. N the car starts up n runs!?!
Here r a few pics of the hoses n where they plug into:
The hose that I capped off..
The hose that I hooked back up..
A pics of the both hoses n where they go/come from..
Any help here would be sweet..
Thanx
Old Mar 31, 2009 | 04:05 PM
FivePointOhh's Avatar
FivePointOhh
in limbo
are you required to have emissions where you are located?
Old Mar 31, 2009 | 04:20 PM
KINGKAOS's Avatar
KINGKAOS
No!
Old Mar 31, 2009 | 06:14 PM
93 LX FiveO's Avatar
93 LX FiveO
well looks like all the smog stuff is still there because that tube that goes behind the motor is part of it.
get some carb cleaner and spray it around that area with the car on.
if it stills out or changes rpm.. you know got a vaccum leak.
Old Mar 31, 2009 | 06:20 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
just plug it then
Old Mar 31, 2009 | 11:33 PM
KINGKAOS's Avatar
KINGKAOS
Yes the smog stuff is still there.. But, just not hooked up(vacuum).. I'm going 2 remove all of it once I research on how 2 do it.. I do have a vacuum leak with those 2 hoses..
Old Mar 31, 2009 | 11:37 PM
KINGKAOS's Avatar
KINGKAOS
Originally Posted by mjr46
just plug it then
I did!!! And when I did is when the car wouldn't start n stall out..
Old Apr 2, 2009 | 01:51 AM
KINGKAOS's Avatar
KINGKAOS
Someone was telling me. If I delete my smog stuff. That my cats will get burnt out/cherry red... Would that happen?
I have 2 keep cats on the car 4 the inspection.. Or I would just get rid of them too..
Thanx
mrtrodonet
Sep 19, 2020 03:12 PM
baddog671
Jul 26, 2016 01:20 PM
9550
Oct 26, 2015 05:01 PM
rksnow1
Sep 14, 2015 08:46 PM
TfcCDR
Sep 14, 2015 12:08 PM
