what is a good top and bottom set for daily driver ?
you could always run the classic combo everyone goes for, it's relatively inexpensive compared to others. just the Cobra Intake, GT-40 Heads, and the ford racing E-Cam
http://www.jegs.com/p/Ford+Racing/750440/10002/-1
http://www.jegs.com/i/Ford+Racing/39...E303K/10002/-1
http://www.tristatecylinderhead.com/...products_id=40
with those heads you'll need some special headders i believe the mac shorties are what most use.
but i think the ones below would fit a tight budget a little better
http://www.tristatecylinderhead.com/...roducts_id=163
cheap and quality DD other than gt40 would be world product heads. A cobra intake, e-cam and WP heads all for under ~$1300 is probable. That is if you are wanting iron heads. Opt for the aluminum IMO.
Trick Flow Steet Burner kit. 2500 dollars and comes with everything but someone to install it. Heads, Intake, Cam, Timing chain and gear set,Headbolts (arp), intake bolts, full roller rockers, poly locks, pushrods, Aluminum Valve covers, Gasket set and I'm sure I missed a few things. I havent seen one get to 300 rwhp but most of them come really close. Excellant in a daily driver, all high quality parts, No guesswork. Makes around 290+hp and around 310+lbft at the rear wheels. Very solid kit
Just so we're clear, you said you'd charge in the ballpark of $750.00 for that install on a car like mine? 12 hours shop labour + taxes about right? What injectors and fuel system upgrades would be required to fully maximize the potential this set up? Would the heads be as durable for 5+ hour long trips as the Victor Jr.'s we discussed?
As far as the heads durability as long as it's installed correctly and the cooling system is up to the task you could run it 24 hours a day seven days a week and only shut it down for an oil change every now and then.
Doing it yourself is great if you feel confident in the work. Getting into the heads or deeper can be scary if you haven't ever done it, especially if its a daily driver. Also most shops guarantee their work so when something stupid happens they pay up.
