mods question for my stang
RE: mods question for my stang
I agree with StangT. Make sure to do some research and get a Head and Intake application that goes well together. Make sure to have a "final project" outcome before starting you mods or you will be replacing/upgrading throughout the process and possibly waisting money. Trust me, I wish I would have done that before buying stuff I eventually replaced and should have never bought in the first place.
yes i recommend you have the intake port matched to the heads for superior flow. find a good cam that will work with the heads and /or supercharger.(i personally run an e-cam with mine) and as far as the supercharger goes, as long as you have the right sized pumps and injectors, tuning can be as easy as one trip to a dyno to have the a/f ratio set. so no not a whole lot of money has to go into tuning.
i have a queston what is eveybodies problem with the 94-95 mustangs there not that heavy. come on shure they arnt as light as the foxes but still we have as much potental as your fox body dude supercharge it
76mm MAF
70mm tb
intake
heads
cam
24# injectors
155 fuel pump
3.55 gears
shortie headers
short throw shifter
180* thermo
3 core radiator
RR
AFPR w/ gauge
MSD 6AL
MSD cap and rotor
MSD super conductor wires
MSD blaster coil
Whatever money you have left put into suspension. If you dont have the suspension to put the power to the wheels then whats the point to have all that power. here is a couple suspension parts
subframe connectors
strut tower brace
lower control arms
70mm tb
intake
heads
cam
24# injectors
155 fuel pump
3.55 gears
shortie headers
short throw shifter
180* thermo
3 core radiator
RR
AFPR w/ gauge
MSD 6AL
MSD cap and rotor
MSD blaster coil
subframe connectors
strut tower brace
lower control arms
