leaking head gasket
there is a small oil leak at te head gasket, rear main, and oil pan gasket. i just picked up the car and started driving it a few months ago. i was putting a plenum spacer in a month or so ago which went south. (messed up the lower intake thread and had to retap, ignored putting the spacer in after that, and immediately started seeing smoke come from under the upper -- that was intermittent light smoke) just the other day after driving for a little the smoke was constant and looked like it was coming from down further in the back near the head gasket (cant see exactly but its from down around there) i was also messing around with trying to get the bolts off for the smog pump delete but tightend them back up cuz i could get one loose. as for the coolant, i need a sugg on this one. i drained the radiator fluid and filled it back up with water only with noting in the overflow. never had any overheating issue (temp gauge usually never went above the second notch on the stock gauge) should i completely drain and just use 50/50?
sorry long but tried getting in as much as i could
Its an involved job, no way about it. Here is what you have to do real quick.
1) Remove Upper Intake
2) Remove Accessories
3) Remove distributor
4) Remove lower intake
5) Remove valve covers
6) Remove Head
(There are plenty of vacuum hoses and electrical connectors to disconnect as you go through this).
Remember to replace the head bolts as well, its not the best idea to reuse them.
6) Remove Head
Anyhow, it sounds to me that your PCV valve popped out and that is the smoke your seeing. The PCV is in the back of the engine, in the lower intake. I'd check that.
6) Remove Head
6) Remove Head
yea i'm inexperienced. first mustang and wanting to take on every project with it. i take it in order to not take the dizzy and be able to get the heads on time needs to be taken to make sure nothing gets smeared. and believe me i will probably break something else in the mean time, lol. i'm hoping to pick up an explorer intake (possible something i broke when trying to put the spacer in) all this info is apprecieated. hope its just the intake for now.
09-27-2015 03:16 PM
