a couple T5 questions
Old May 4, 2009 | 03:47 AM
302army187's Avatar
302army187
get another stock T5, and dont power shift it. it will live just fine.
(also launching all out on slick's is a no-no)
Old May 4, 2009 | 01:31 PM
wlp302's Avatar
wlp302
Anybody ever heard of a "z spec" gear upgrade? My local t5 rebuilder said he can do it. Otherwise what gearset should i choose for a budget rebuild?, i cant afford the high end like astro.
Old May 4, 2009 | 01:40 PM
AdderMk2's Avatar
AdderMk2
Banned
the Z isnt much stronger than the late WC T5's... he advantage is in the 2.95:1 first gear ratio
Old May 4, 2009 | 01:46 PM
wlp302's Avatar
wlp302
Does that mean first gear in a z spec is quicker or longer than a normal t5?
Old May 4, 2009 | 03:05 PM
AdderMk2's Avatar
AdderMk2
Banned
longer
Old May 4, 2009 | 04:35 PM
FivePointOhh's Avatar
FivePointOhh
in limbo
the physical design and overall weight of the t5 make it incapable to withstand large amounts of hp and torque for long periods of time, z spec, g force...whatever the hell it is internals....its still a t5. especially with powershift and hard launches you'll significantly reduce the life of a t5.
if you're going big...save for a TKO. less money in the long run.
Old May 4, 2009 | 05:41 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
save your money for a tremec tranny....
Old May 4, 2009 | 07:26 PM
turbosha's Avatar
turbosha
i was gonna say it too. if you want a t-5 this is the place to get it.
Old May 4, 2009 | 07:29 PM
turbosha's Avatar
turbosha
not just the tranny. different bellhousing,clutch,cross member,shifter,=more weight than t-5 also.
Old May 4, 2009 | 08:21 PM
AdderMk2's Avatar
AdderMk2
Banned
tremec transmissions use stock fox bellhousings, stock fox clutch forks, the tko 500 uses the 10 spline (stock) clutch, and they come with a shifter (new) and the crossmember issue... cut the tack welds on your stocker, slide it back and have it re-welded after the trans is in
If you went TKO600, you only need a new clutch disk... not a whole clutch
