Horsepower Help
Old May 11, 2009 | 02:55 AM
302army187's Avatar
302army187
Originally Posted by mejus16
dats great i have an auto . gt 09. if i put those mods i could get over 330 rwhp.. but how much does 94 gt makes stock..?
a 94gt put's about 190hp to the wheel stock.
and no, you couldent put those mod's on your 3v 4.6l, you just sound crazy with that comment.
Old May 11, 2009 | 11:14 AM
Redrider69's Avatar
Redrider69
The car is 5 speed, its has factory rear gears in it too.
As far as the parts, everythings there, I have all the factory parts, boxes and recipts for the new parts. The heads say afr right on then, holley right on the intake, yep its got everything there.
What kind of cam would you guys suggest I go with, give me a good setup. Also any suggestions on the exhaust?
Thanks
Old May 11, 2009 | 02:10 PM
JD5.0stang's Avatar
JD5.0stang
ditch that cam. Get an E cam or maybe an F cam. Trick flow makes some good ones too. I have flowmaster 40s on my car and its sounds really nice. Clogged mufflers could def hurt your power. So get the flowmaster cat back or just mufflers and swap that cam out. with AFRs you should be around 315hp and 325 torque or better
Old May 11, 2009 | 02:30 PM
grnstang's Avatar
grnstang
if you want to make more horsepower do NOT buy a ford letter cam. (E,F,B i.e) look up camshaft innovations and talk to them about making you a custom grind cam specifically for your set up. You might need to change valve springs to match the cam, but it will be SO worth it.
Old May 11, 2009 | 02:48 PM
AdderMk2's Avatar
AdderMk2
Banned
Jay from CI provides matching springs for his cams
Old May 11, 2009 | 04:12 PM
Redrider69's Avatar
Redrider69
So do you think the bad exhaust and crappy cam are my problem then.
So I wanna talk to Jason at camshaft inovations and tell him my set up, and they'll grind me a custom cam? What's that usually run, I think ill deff go that route.
Also since ill have the motor apart somewhat, is there anything else I can do to get more power, other then nos or a blower, or am I pretty much maxed out.
Thanks.
Old May 11, 2009 | 04:36 PM
grnstang's Avatar
grnstang
yeah that should help. i'm curious...what chip are you running on your car? who tuned it?
Old May 11, 2009 | 04:53 PM
AdderMk2's Avatar
AdderMk2
Banned
~$400 ish
Old Mar 26, 2020 | 08:23 PM
Mmoore88notch's Avatar
Mmoore88notch
These are the correct parts, im the guy building it. I adjusted the valves this evening but I'm still needing to put the 79 waterpump on. Only accessories im running is alt n water pump of underdrive crank pulley.. Sooo its still not too late to put a different cam In it. I only paid 150 for the cam used.. So I can most likely get my money back out of it n get something better. Springs are rated up to 600.
thank you guys for taking the time to respond! Means alot
Old Mar 26, 2020 | 08:28 PM
Mmoore88notch
WOWWWWWWWW wrong thread!! Everybody ignore this please...
Jan 6, 2016 07:03 PM
GimpyHSHS
Sep 18, 2015 12:27 PM
Sep 18, 2015 12:25 PM
Other Professional Racing
Sep 10, 2015 11:41 AM
mustangfan305
Aug 7, 2015 11:09 AM
