how much spray can i run?
im lookin to see how big of a shot of nos i can run safely without causing my engine any damage and what ill need to get to support the kit ivenever used nos before so any advice would be great first ill list what i have for motor mods and fuel system stuff, 302 bored .30 with forged flat tops w/ 4 valve reliefs, gt40 cast iron heads(rebuilt), machined crank (lightend, .10 machined, knife edged) stock rods, holley contender intake manifold, msd distributr, edelbrock 600 cfm carb, 1in spacer plate, 2 1/2 exhaust no cats, mac ceramic headers, aluminum radiator, dual electric fans, rci fuel cell and some ****ty little electric fuel pump (im sure ill need a better one for spray), pretty decent mid range cam matching lifters, hardened pushrods, 2k stall tci convertor, c4 w/ shift kit +kevlar clutches and billet servos so ya let me know what i need for a fuel pump, puge setup? what kinda shot is safe for the street and wont destroy my engine? any help is awesome
first, dont call nitrous "nos" you will get laughed at.
you can run a 100shot all day and night. but sence you are carbed, spend the money right and buy a plate system that bolt's under your carb. you can run a 150shot (WET!) pretty easy, just put it on the dyno to make sure your not rich.
you MUST upgrade your fuelpump, i got my 255lb high pressure pump for $70 to my door.
also go with a step colder plug, gapped to .30-35
run highest octane gas you can get your hand's on.
and that's pretty much it. it's not complicated. But if your running a big shot, the nitrous will find a weakness in your car.
engine, tran's, gaskets, rearend, etc.
try to read up a bit more, there is plenty of info out there on the internet to prevent you from doing something stupid.
NOS!!!hahahahahahahahahahahahha!!!!!!!!!!!!!!!!!!! !!!
First since you are carbed you want to run a high volume low pressure fuel pump. Then let your wallet and courage decide the amount of Nitrous you decide to use. I hear a lot of people using a 200 shot. I wouldn't risk over 150 and would feel confident with a 100 shot.
alright guys lol i wont call it nos ne more haha so what do you think should i grab a 8 to 9 psi pump that flows like 90 gph? that should be about right for a 100 shot id think, im not lookin for anythin over the top i jus like to have a little extra insurance im right around 280-300 hp right now so im thinkin a 100 shot will be more than sufficient its only a street car
