fuel pump ???
my fuel pump took a sh_t the other day and im thinking about replaceing it with 110lph pump for further upgrades to fuel system will it be ok for right know to use that pump with a stock system 19lb injector and stock reg!! thanx
I got a 110Lph from brothersperformance.com for about 75.00. No problems at all, and that pump is good up to 350 hp or something, good enough for the daily driver. The install takes about 25-35 minutes. Something I found out is that you should maybe change out the tank seals while you got it off. My fuel filler pipe seal was ripped and when i decided to reuse it (didnt have another) my tank would leak when I would top it off. So I had to drop the tank twice. Just some FYI.
mrappe
Sep 26, 2015 10:16 AM
