93 5.0L 5spd hesitation
Old May 19, 2009 | 01:43 PM
monkihead's Avatar
monkihead
Default 93 5.0L 5spd hesitation
As titled, car gives a hesitation under load @ roughly 3800-4000. It doesn't care on how much throttle, does it with mild to wot. No codes, mil light doesn't come on. Low rpm power suffers @ 12 degree timing, have it set at 16.
Car has-
gt40 intake
190cc runner aluminum heads
30lb injectors with matching c&l tube
bored .030 over
E303 cam
Any clues to the culprit???
Old May 19, 2009 | 02:01 PM
AntiRiceRacing's Avatar
AntiRiceRacing
Im having the same issue, pretty sure all my mallory stuff took a **** and is causing it.
Old May 19, 2009 | 02:45 PM
monkihead's Avatar
monkihead
it was worse with the stock tfi distributor, replaced it with a mallory. should I put the stock unit back on with a new module??
Old May 19, 2009 | 03:33 PM
AntiRiceRacing
The ignition might not be your problem, clean your MAF sensor and see what happens.
Old May 19, 2009 | 04:29 PM
monkihead's Avatar
monkihead
How do you clean the maf? Its a big tube with a calibration tube. 73mm maf.
Old May 19, 2009 | 07:01 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
go to the parts store and buy a can of maf cleaner
Old May 20, 2009 | 04:45 PM
monkihead's Avatar
monkihead
Cleaned maf, no dice. checked voltage on TPS and it was too high. 1.2/1.3 volts. I pulled out the throttle screw and now it won't start. I reset timing to 12 degrees and is hard to start. if I set timing to 18 degrees, it starts, revs but surges after a while. would hate to sell due unresolvable issues.
Thunderball
15
Nov 22, 2015 11:49 PM
Omgitsa88Stang
Oct 5, 2015 07:33 AM
2poor4u2
Sep 26, 2015 11:08 AM
Sep 17, 2015 07:32 PM
Sep 10, 2015 08:39 PM
