cam shaft seal
Old 05-29-2009, 10:38 PM
92mustang510
92mustang510's Avatar
Cool cam shaft seal
how hard is it to change it with the motor still in the car. i can see oil leaking between the tranny and the engine block its not the oil pan.
92mustang510 is offline
Old 05-29-2009, 10:46 PM
67mustang302
67mustang302's Avatar
Probably the rear main seal.
67mustang302 is offline
Old 05-29-2009, 10:49 PM
92mustang510
rear main seal is the seal arount the crank shaft right or no
Old 05-29-2009, 10:52 PM
AdderMk2
Banned
AdderMk2's Avatar
yes. it is
AdderMk2 is offline
Old 05-29-2009, 10:55 PM
67mustang302
That's the most common source for an oil leak between the block and trans. But check to make sure you're not getting a valve cover leak, the oil can run down and seem like it's coming from a seal when it's not.
Old 05-29-2009, 11:03 PM
92mustang510
about how long should it take. will i need to replace any other seals to replace that one
Old 05-29-2009, 11:11 PM
67mustang302
You have to pull the trans.
baddog671
07-26-2016 01:20 PM
bradleyb
11-27-2015 07:50 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Quick Reply: cam shaft seal
