tuning
tuning
Ok guys. i have heard so many different things about tuning the 5.0 mustang. some guys tell me that there is not much to tune other then the timing and that getting a tune is a waste of time and money. then on the other hand, i have had guys tell me that they picked 30 plus horses at the wheels just from a tune. Wat do you guys think.
oh and if you know any good places that tune let me know. i live near the shore in New Jersey.
I don't have much knowledge of tuning but from what I understand, on the 5.0s you basically have the option of getting a dyno tune (with or w/o a chip?) or tuning software like Tweecer, Anderson PMS, and a few others.
It also depends on what kind of setup you have. If you don't have a ton of mods or engine work, then a tune isn't really worth while and it won't get you the HP gains. I'm sure everybody else can elaborate and I'm actually curious to see some responses myself b/c I'm doing an engine swap with HCI soon
i have heads,cam,roller rockers,smog delete,hardened pushrods, ford racing lifters,70 mm throttle body and spacer,and ford racing mass air meter,BBK cold air, headmen headers,full exhaust and a GT40 upper and lower intake on my car. basically everything other then pistons crank and block are aftermarket. i think you are right tho. they are very basic engines so there is not much to tune.
My opinion is slightly different, so I will offer up my thoughts....
I try to think in the 'long term' when making changes/suggestions for others.
When/if you get into the higher performing mods (h/c/i, boost, >24Lb injectors, etc.) are you going to be tuning the car yourself using a J3 chip like a TwEECer, Moates F3, Moates QuarterHorse, or similar? Maybe a non J3 device like the Anderson PMS?
If so, then I suggest investing in this tuning system As Soon As Possible. There is a learning curve to using these devices, and the sooner you take it up, the sooner you will learn....
If you are going to take the car to a dyno shop, then the above is worthless...
I said Tweecer because I have had great experience with it. It has an excellent support group and is also reasonably priced at $500. It's all a personal preferance and one I have knowledge and experience about. ahittz, have you actually used a Tweecer or Moates? I'd reccomend a PMS, but to be honest, I do not actually have experience with it. I know Kweb is running one.
