2 problems
Old Jun 7, 2009 | 08:30 PM
94mustang94's Avatar
94mustang94
Default 2 problems
My car went way up in oil pressure out of nowhere today....it way out of the normal range sitting on the H. Why would it do this.... it only did it for about 5 min and went back down normal..any suggestion?
My car heats up sometimes a little too hot like to the "A" in NORMAL and then comes back down to normal...thermo sticking?
94 gt 5.0
Old Jun 7, 2009 | 09:06 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
try a new sending unit for the oil pressure as for the overheat condition, when does it run hotter?? stop and go traffic or highway???
Old Jun 7, 2009 | 09:27 PM
67mustang302's Avatar
67mustang302
Make sure you find out what your oil pressure actually is, if the relief valve stuck shut and it over pressures you can blow the gallery plugs out, and then you'll have 0 oil pressure.
Old Jun 7, 2009 | 10:13 PM
94mustang94
it will run hot just at random times not really any particular time. im thinking the thermo is sticking but my mechanic supposedly replaced it
Old Jun 7, 2009 | 11:06 PM
08 Bullitt 2310's Avatar
08 Bullitt 2310
Do the gages go up and down together.My car has fluctuating issues due to a crappy connection I think............
Old Jun 7, 2009 | 11:14 PM
94mustang94
i noticed at one poit that as soon as the temp went down so did the oil pressure and then the oil pressure went back up w/o the temp
Old Jun 7, 2009 | 11:53 PM
08 Bullitt 2310
Sounds like a cluster connection issue.I would take it out and clean the connections before I did anything else.Check to see that the charging system isn't overcharging the system as that will compound the other possible issues.Make sure all of the ground connections are clean and resistance free.
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
