@TURBOING@ The Pony
@TURBOING@ The Pony
Over the last few months ive been collecting parts for my rear mount turbo kit. so far i have Turbonetics T04E-50 Stage 3 .48 AR turbo,,,oil scavange pump,,38mm wastegate,,oil lines/fitting/vaccum lines,,air filter,,all necicary piping,,the exhaust inlet flange adapter,,will weld the wategate pipe just b4 the turbo set vaccume line,will have oil return line routed back to valve cover,,will pipe intake tuping to throttle body,,,exhoust routed to turbo exhaust intake,, i plan on running 5 lbs of boost? the only turbo supporting mods are, 9mm wires, ngk plugs, msd6AL, super coil, afpr, walbro 255, moter interals are stock, transmition,, new torq convert vals bands seals shift kit etc.. i chose this turbo in fear of lag but im not stuck to it yet let me know what u all think.
~Jay
~Jay
that t04e is going to be way too small. i run two of those on my motor
duals of what you currently have or a 60+mm. (just off of other builds i've seen) my neighbors build used a 76mm and it spools around 2600-2800rpms. little too big for a stock motor IMO.
and yea im taking lucky's response as an agreements to what i stated. personally i would run it to the front sump and not the rear. thats my opinion though.
i believe i have found a remedy as to the turbo size, it is as follows:
Compressor:
- Wheel: 60-1 / T04S
- Housing: .70 ar
- Big T04S / 60-1 Housing w/ 4.00" Inlet & 2.50" Outlet
Turbine
- Wheel: P-Trim
- Housing A/R: Your Pick From Below
- Housing Style: Your Pick From Below
(Let us know what A/R you want when you make payment)
Your Pick Of Exhaust Housing & A/R:
#1: T4 Divided with .70, .84, 1.00, 1.15, 1.32 OR 1.52 A/R
#2: T4 Undivided .61 or .70 A/R
Center Section
- Oil Cooled
i finally found what sts turbo systems big secret turbo was and this is it,,now just need the final details,ide like the same turbo they run on the camaros.
suggestions comments on final size?
Compressor:
- Housing: .70 ar
Turbine
- Wheel: P-Trim
Center Section
- Oil Cooled
ya i was agreeing with 5pointohh.
http://vortechsuperchargers.com/supp...%20Ford%20Cars
click on the install instructions for 86-93 mustangs and on page 2 of the manual (14 of 30 on the top of the pdf window) there is a picture that shows where to punch the hole
as far as the turbos goes, i would look at 62-67mm both will get you to 400rwhp+ and still spool up well. 60mm should work but if you plan to go past 400rwhp in the future i wouldnt buy it. thats a good size turbo for a stock 5.0 and thats about it. just remember, i run twin 57mm and your talking about running just one 60mm
