couple of 351w ?s
Old 06-19-2009, 10:34 AM
donsmoke
donsmoke's Avatar
Default couple of 351w ?s
I know this pb sounds like a stupid ? but I cant find the info anywhere. What are the stock specs on a 351w as in the rod length and piston size ect. ect. the reason im asking is im looking into a 351w swap instead of a aftermarket 302 block and im trying to find forged internals for it but i want to keep it a 351 for reliability but I cant find a kit like that so I was trying to get everything seperate but dont know what sizes im looking for.
Also I have a 79 F-150 rotting in the driveway with what i have been told is a 351m or 400ci whatever its called would i be able to use that block or is that something different??
Thanks alot for any help guys.
donsmoke is offline
Old 06-19-2009, 04:02 PM
ryan_89_mustang
ryan_89_mustang's Avatar
351M isn't worth the trouble its totally different then the Windsor motor its a destroked 400 which isn't really good for anything other then a truck.
ryan_89_mustang is offline
Old 06-19-2009, 09:46 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
351 m is a truck motor and that's where it should stay!!!
mjr46 is offline
Old 06-20-2009, 10:38 AM
87notch408
87notch408's Avatar
the 400 is actually a good engine. I saw a builders shootout where a 400 beat all kinds of engines from different manufactures. I am sure you can google it and find it. The 400 does accept 351C heads, Cams, Timing Chains, Oil Pans amongst other small item.
the 351M is a good engine for what it is, just not to many performance parts for it. I would make sure you have a 400 and not a 351M
87notch408 is offline
lovesilver
Members Mustangs
05-09-2019 09:18 PM
Thunderball
15
11-22-2015 11:49 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
Matt's 95 Stang
10-05-2015 07:16 AM
guitarman376
09-30-2015 05:54 PM
Quick Reply: couple of 351w ?s
