02 GT Rear ---> 85 Fox
Will a 8.8" rear from an 02 Mustang GT fit under an 85 Fox hatchback? Not for me, but I'd like to help a guy out who has a 7.5" in his 85. Is there anything that would make the job difficult?
TIA!
TIA!
verbatim from a very reputable source and very good write ups for 5 lug swap, disk brake swaps.
"The '94-98 cars rear axle shafts are .75" longer than the stock axles on the '87-93 cars. Be sure you note this longer axle if you are running 9" wide wheels because you will need the wheels with the extra offset like the M179 Ford '95 Cobra Rs (6.45" 36mm) -- which are now discontinued! You can use the 8" wide wheels without issue, but if you want 9" wide wheels you need to convert the brakes to use the stock rear track with Ranger axle shafts! "
"The '99-04 V6/GTs are even longer at about 1.4x", so you will NOT want to get the axle off a '99-04 car. Also the control arm bolts are larger, thus the UCAs and LCAs are not a direct bolt on - unless you install 94-98 bushings in them. You can use the brake hardware off the 99-04 cars, but you will need to use the 94-98 axle shafts in the 79-98 axle housing."
KingRando
10-01-2015 11:16 AM
wishinsky
09-21-2015 09:48 AM
09-16-2015 07:53 PM
