TIMING PROBLEMS?! HELP!!!
Old Jul 2, 2009 | 12:48 PM
revolver001's Avatar
revolver001
Default TIMING PROBLEMS?! HELP!!!
I bought a 84' Mustang LX with a 5.0(none H.O.) Swap in it(originally had 2.3) I replaced all the tope end gaskets and the water pumps, ect because it was long over due. Now that it's together and the order is just as it was when it ran i can not get cylinders 2,3,4 to hit at all even though they have both a strong spark and fuel. No matter how many degress the distributor is adjusted they still wont fire. This lead me to believe it was a timing issue even though the other 5 cylinders where firing pretty close and cylinder one was perfectly hiting where it needed to. It is camed(i dont know what cam it's useing but ive also tried the H.O. order in hopes it used the 351 cam but still nothing). Wires,plugs, Cap, rotor, modual are all new also. If you could give me any ideas i'd appreciate it!
Old Jul 2, 2009 | 08:27 PM
Pony 5.0's Avatar
Pony 5.0
Maybe you stabbed the dizzy wrong like I did once. Follow Adders's sticky in Tech Articles on how to stab a distributor.
Old Jan 22, 2011 | 07:55 PM
joshy429's Avatar
joshy429
Default 84 h/o conversion
I Got A 90 Model LX mustang Had a 3.8 in it got tired of problems. so i swaped it to a 5.0 and heres the prob...its a 84 non ho block so i put all new fuel injection stuff on it switched it too a 351w firing order.. also changed a couple of fuel injectors around. but it still missing sum i figured i may have to change to a 351w camshaft in order for it to run again any ideals???
Old Jan 23, 2011 | 09:35 AM
projectresto83's Avatar
projectresto83
M.A.D. Motorsports
Yea, read the rules and start your own thread......
you do not have to put a 351 cam in the 302 block. there are 302 cams with the 351w firing order. Have you tried switching your firing order around to make sure you have the right one?
Old Jan 24, 2011 | 10:19 PM
joshy429's Avatar
joshy429
yea i changed firing order around to like 4 different firing orders .. so i figured if i put cam out of sumthing i new wut the firing order would be... and no i havnt read rules yet cant figure out how to make a new thing yet..
djbigskrilla
Sep 20, 2022 01:04 AM
Cin K
Aug 31, 2015 07:31 AM
stormesixx
Aug 25, 2015 09:11 AM
1st 4 eyed fox
Aug 24, 2015 06:56 PM
KEM Motorworks
Aug 14, 2015 10:13 PM
