Leaking Coolant
Old Jul 3, 2005 | 06:18 PM
luckypballer's Avatar
luckypballer
Default Leaking Coolant
I just finished replacing my Balancer, Timing cover, and water pump. Got it all put back together and the car runs great, except that it is leaking coolant. I couldn't pin-point the leak for hours then i noticed it. There is a little slit in the bottom of the timing cover i must have missed it with rtv or something, just wanted to know if this is a common problem and why in the hell is that thing even there?
Old Jul 4, 2005 | 01:41 AM
mustang8719's Avatar
mustang8719
Default RE: Leaking Coolant
The picture is a little blurry but that notch should be for if the pump fails.
You probably have a bad seal with the water pump.
I had the same thing happen before.Once I installed a new gasket all was good.
Old Jul 4, 2005 | 12:05 PM
luckypballer
yeah, this thing is pissing me off like none other. Also is it common for a temp gauge to jump up and down. Because right now mine wont go above the M in normal but it constantly jump up and down
Old Jul 4, 2005 | 12:20 PM
mustang8719
There might still be an air pocket somewhere.
Mine did that when it was low on coolant due to an air bubble.
4cylinderplus2
Oct 9, 2020 07:45 PM
bradleyb
Nov 27, 2015 07:50 PM
jerrytubes
Oct 23, 2015 12:11 PM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
wraith777
Sep 28, 2015 10:49 AM
