short belt issues....Help?!
got the wrong image from the guy. But to clarify, i spliced the ASI so that the connector just next to the asi plug could be connected, i took the other plug, cut the three wires and put ring connectors on the charge post as well as a heavy gauge wire that had a 140 amp fuse which goes along the radiator support and then attatches to the positive post on the battery.
I'm running my belt routing a different way than in any of those pictures and have no belt to belt clearance issues. Mine is basically run the same as in the picture with the purple belt, however my waterpump and crank routing is the opposite way, similar to the red belt.
I hope you upgraded your alternator to solenoid power wire along with the alternator...
12 gage seems a bit small for handling alternator output. I'm running a 4 gage with a 200 amp in line fuse on my 130 amp alternator set-up. That is in addition to the two black wires that are stock. I have my cable coming off of the solenoid, then it runs along the radiator support next to the stock wiring harness, below the air box, then up to the back of the alternator where it connects to the post on the back of the alternator.
The alternator power wire should run directly to the starter solenoid. It attaches on the same post as the power wire from the battery. Since the battery and alternator wire both run directly to the same post on the solenoid, it essentially acts like a direct cable from battery to solenoid. I do NOT know running the alternator to battery will cause problems as I have not tried and don't care to.
junior04
09-28-2015 10:53 AM
autoedit
09-27-2015 06:37 PM
