going to a carb. on a 95?
Has anyone changed over to a carb.?? If so what have they done away with-wiring ect...? What type manifold have you used, I'm thinking of a victor JR? I won't be using the EAOD trans. I will use either an AOD or C-4 so the computer will be gone.</P>
</P>
Thanks For your help!!!</P>
VFAST, It currently has the stock motor in it, but I have another thats a 306 using a late 70's early 80's block w/ flat top TRW. Hoping to get around 9.5-10. to 1 comp.w/ stock heads and some milling and decking to get there.Will most likely use a hyd. cam to turn it around 6 grand</P>
Plan to run MSD ignition stuff. Looking for info on elimating the stock wiring, but not hacking it up, just using what I can to do what needs to be done.Also opinions on intake manifolds victors come with good remarks, anybody using it or others???</P>
I just bought this car and the mustang stuff is all new to me.</P>
</P>
</P>
Thanks </P>
Daddys Girls GTs
09-14-2015 08:46 PM
