Bumping Timing Question
Hey guys im posting another newb question! here it goes.
Iv read that bumping your timing can free up some power! and since my 5.0 is pretty much stock and i have no idea what the timing is.. probably has never been bumped.. im looking to change it up a bit.
my buddy said he has a timing light and that he would come over and help me but what should i bump my timing up to? and is there anything i should do or look out for?
Thanks!
Thanks!
Advance the timing 1 degree, drive and listen for detonation. If there's detonation, go to higher octane fuel or retard the ignition. If there's no detonation you can bump the timing up some more and check, etc.
https://mustangforums.com/forum/5-0-...ng-sticky.html
Read that before you start.
It's worth maybe a couple of horsepower on a stock motor, but when you start replacing major engine components timing becomes more important/beneficial.
Detonation can be subtle or something that'll make you think the car is exploding.
Subtle detonation is like a slight knocking sound that gets faster as RPM's rise. I'm sure you'll know what the unsubtle sounds like.
