Bumping Timing Question
Old Aug 4, 2009 | 05:01 PM
domindart's Avatar
domindart
Originally Posted by 1ATony
I had mine set to 14 without a hint of detonation.I knew guys around town that had them turned up even higher than that.As long as it doesn't ping you'll be ok.
Yap, mine is set to @ 17* now. You will notice a slight difference is power.
I originally had mine set to 21* !! But it started to surge at idle and some pinging I think.. so I set it back down.
Old Aug 4, 2009 | 05:22 PM
Dj_Seph's Avatar
Dj_Seph
I think I'll go time mine tonight. At around 3000rpm going WOT I can hear a ticking sound. Baaaaaaad.
And I'm running 91 with a whole bottle of octane booster. I wonder how high my timing is.xD
Old Aug 4, 2009 | 10:46 PM
r1sky5.0's Avatar
r1sky5.0
So when I bump my timing to 14 what grade of gas do I use?
Old Aug 5, 2009 | 01:46 AM
domindart's Avatar
domindart
92octane
Dj_Seph's Avatar
Dj_Seph
91-93 of course.
Old Aug 5, 2009 | 09:56 AM
Fox23's Avatar
Fox23
k guys i went to bump my timing with my buddy but when he shined the light on my balancer it didnt show the marks. then when i took a wire brush to it i could see some markings but had no idea how to tell which was what and how to read them.. it was just 2 white lines like an inch apart? so i manually turned my distributor but i forgot to disconnect the spout lmao.. so right now my dizzy is turned a little but i heared that the computer will automaticly change my timming back to stock if i didnt disconnect the spout? is this true? even tho the dizzy is turned a bit? what should i do?
Old Aug 5, 2009 | 10:30 AM
Tony71502's Avatar
Tony71502
Take the spout out and reset the timing.
Old Aug 5, 2009 | 10:37 AM
Fox23's Avatar
Fox23
will my timing be affected due to me moving the dizzy previously? or will my timing stay the same even tho its been moved? so i can just disconnect the spout and rotate it a little then connect it back and im good?
Old Aug 5, 2009 | 12:30 PM
r1sky5.0's Avatar
r1sky5.0
Alright good to know. Just wanted to make sure before I messed anything up!
Old Aug 5, 2009 | 02:50 PM
Tony71502's Avatar
Tony71502
Take the spout out when the car is running and you will see how the timing changes. When the spout is out, retard/advance the timing until it is at a degree which you know (10*?). Then adjust from there.
Make sure you don't get caught in the fan. :P
67LimeCoupe
Nov 25, 2015 08:55 PM
GimpyHSHS
Aug 29, 2015 06:30 PM
stormesixx
Aug 25, 2015 09:11 AM
Tyoung68
Aug 25, 2015 04:31 AM
ding56
Aug 14, 2015 02:40 AM
