Adjustable Clutch Cable HELP!!!!
Im still having problems with my clutch cable i have it adjusted to the right height for it to engage but now the pedal is hard as crap to push in. how do i fix this? I also have another question about routing the cable im guessing i have it not in the right spot if i keep on having these problems. i have the cable routed from the firwall to the mounting spot and then running it under the motor mount to the clutch fork. Is this right or do i have it routed the wrong way?
RE: Adjustable Clutch Cable HELP!!!!
you should be able to wiggle your pedal some. see what happens is if you don't have any slack in your cable when you mash the pedal down your going to engauge the fork fully before the pedal actually touches the floorboard. Continuing to put pressure on the pedal to make it hit the floor will fray and break your cable.
do i have the cable in the right spot? beside the master cylinder and under the motor mount to the clutch fork right? Im going to loosen the firewall adjuster all the way and undo the cable and the fork and redo the whole thing so just tell me step by step of what to do i just cant get it right
