check engine light
have a check engine light coming on (sometimes) about 15min into driving it. i took it on a few long trips and havent noticed anything wrong when driving it. it seems to come on when im at a half tank of gas. i heard that i could run lean at half tank if u got advanced timing. true? or is it my o2 sensores? id turn off the car and start it back up and no light for a while.
I don't know about the running lean with a half tank of gas but, some fuel pumps going bad won't start when the gas gets below half a tank. Usually the car can be started when beating on the tank with something or loosening the gas cap.
Fuel pumps would last longer if everyone filled their cars before the gas hand got to low. The gas cools the pump.
If you do replace the sensors use a little anti seize on the threads.It'll make life allot easier next time around,if you ever have to replace them again.
Some sensors already come with anti seize on them.
Regarding the half tank of fuel + advance timing = lean...... =
LUK
same problem happen to me, i couldnt run codes because it would disapear meaning i would be drivign and it would go on an aoff then when i parked it it would go off
but i was running rich or lean i forgot which one
