Help!!! Throtle cable problem
Old Aug 22, 2009 | 02:22 PM
canman87's Avatar
canman87
Default Help!!! Throtle cable problem
Ok Im done with the build of my 347. I droped the motor in my car but ran into a problem. The throtle cable is hitting my tall valvecovers. There must be a simple fix. I used roller rockers that why im going with the tall valecovers. My car is fuel injected and I heard that you cant run tall valvecovers with injected car???
Old Aug 22, 2009 | 04:14 PM
mattdel's Avatar
mattdel
is it hindering the cable in any way? if it still works properly, i'd just leave it, unless you're going for a cleaner look.
Old Aug 22, 2009 | 07:59 PM
canman87's Avatar
canman87
I only have half throttle. it is the piece on the throttle body the metal piece where the cable connects. When it I
s drawn back it hit the valve covers.
Old Aug 22, 2009 | 08:33 PM
Boss_Hotrod's Avatar
Boss_Hotrod
Put a intake spacer on it. Thats whats on my car. be careful though because it may hit your hood.
Old Aug 23, 2009 | 08:00 AM
canman87's Avatar
canman87
it has an intake spacer already. I have a 3in cowl hood so not a problem on hitting the hood.
Old Aug 23, 2009 | 09:02 AM
AdderMk2's Avatar
AdderMk2
Banned
you dont need tall valve covers.
Im running comp cams pro magnum rollers on my canfield heads and stock fox valve covers
Old Aug 23, 2009 | 09:11 AM
canman87's Avatar
canman87
what did you do to make the valve covers fit? cut the baffle out?
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
ccdguy
Sep 19, 2015 05:20 PM
wilsonro
4 Cylinder NA and Turbo
Sep 11, 2015 07:13 AM
DoctorScary
Sep 9, 2015 07:53 AM
