Gears?
Gears?
I have a 94 AOD-E, and am looking into geting gears. I have an appt to get my transmission overhauled and a shift kit installed, im going to do gears as well but am stuck in between 3.55 or 3.73. This is my daily driverbut i want to be able to romp every once in a while. Which would be a better gear ratio for a daily driver stang? My appt. is fri so any advice would much appreciated!!!
Gears?
Originally Posted by JT Steeda
I have a 94 AOD-E, and am looking into geting gears. I have an appt to get my transmission overhauled and a shift kit installed, im going to do gears as well but am stuck in between 3.55 or 3.73. This is my daily driver but i want to be able to romp every once in a while. Which would be a better gear ratio for a daily driver stang? My appt. is fri so any advice would much appreciated!!!
Gears?
I have a 95GT with the same AODE as your 94. I installed 3.55 gears and I couldn't be happier. It realy helped wake up the car. I would probaly not go with the 3.73 gears since it is your daily driver. And I most definetly would not go with the 4.10 gear or you will wish you hadn't. Your motor will be turning like 5 grand at 70mph and that's not good.
Gears?
Gears?
Hey you, don't tell me I'm misleading..... I have 3.55 gears and my car turns about 2700 at 70mph. If I had went with the 4.10's the rpm would be significantly higer. Don't you dare tell this dude to go with the 4.10's cause he will be so disapointed. His car will only be good for doing donuts in an empty parking lot. If he has his mind set to go deeper than 3.55's he should go with the 3.73's but DEFINETLYnot the 4.10 gears. Mind your own business when you don't know what you're talking about. </P><edited><editID>jhogan2424</editID><editDate>37943.4498148148</editDate></edited>
Gears?
Hey you, don't tell me I'm misleading..... I have 3.55 gears and my car turns about 2700 at 70mph. If I had went with the 4.10's the rpm would be significantly higer. Don't you dare tell this dude to go with the 4.10's cause he will be so disapointed. His car will only be good for doing donuts in an empty parking lot. If he has his mind set to go deeper than 3.55's he should go with the 3.73's but DEFINETLY not the 4.10 gears. Mind your own business when you don't know what you're talking about. </p>
