code scanner help!!
Old Aug 25, 2009 | 01:58 PM
chickenbutt's Avatar
chickenbutt
Unhappy code scanner help!!
I have an Actron Code Scanner Model: CP9015 and i didn't buy it or never worked it.. it was given to me and im not sure on how to use it.. I plugged it in to test the codes and nothing happend played with the switches and nothing.. Only thig that happens is the STO (self test output) light will light up but eventually goes off.. I been to the site but either my computer won't load the instructions or my internet is just bein slack.. Anyone have any advice?
Old Aug 25, 2009 | 02:04 PM
TrimDrip's Avatar
TrimDrip
FudgeDrip
there is a large black plug and a little grey plug. Both need to be plugged in.
I have an actron manual at the house and can help you more later if the model number is the same.
Old Aug 25, 2009 | 02:25 PM
chickenbutt
That would be great, I had it plugged in correctly both plugs in at the back corner of the engine bay..But like i said it didn't do anything but light up that one light..
Old Aug 25, 2009 | 02:32 PM
TrimDrip's Avatar
TrimDrip
FudgeDrip
If it is like mine, there are two switches on it. One for noise and the other is for test.
Try plugging it up with the scanner not on test. (I can't remember the name of the setting opposite of test).
After plugging it in like this, get in the car and turn the key to the on position. Then shift into neutral.
After that, get out of the car with the key on and flip the tester to test. You should start hearing relays clicking and what have you. Then your codes should start coming.
Be careuel not to switch it off test until it is unplugged or it will erase the codes in the computer.
Old Aug 25, 2009 | 02:34 PM
Tony71502's Avatar
Tony71502
1. Did you make sure the batteries were good in the scanner
2. Did you plug it into the cigar lighter, also.
3. Is your cigar lighter fuse blown.
Old Aug 25, 2009 | 02:38 PM
chickenbutt
mine doesn't plug into the lighter place.. I edited my post before and posted a pic of my scanner the switches are AUDIO on/off and the other is TEST and HOLD.
Old Aug 25, 2009 | 02:45 PM
TrimDrip's Avatar
TrimDrip
FudgeDrip
We got the same one. Try the steps I wrote in my other post. If it doesn't work, you will need to get the battery tested or just get a new one. It shouldn't be over 5 bucks.
Old Aug 25, 2009 | 03:05 PM
chickenbutt
yea im sure the bat. in it still works like i said in my first post i think the red STO (self test output) light comes on.. but I am walkin out the door to try this right now! thanks.
Old Aug 26, 2009 | 08:28 AM
chickenbutt
ok so i tried it and still nothing... the light just stays on..???
Old Aug 26, 2009 | 08:36 AM
TrimDrip's Avatar
TrimDrip
FudgeDrip
When you flipped it to test with the key on, it just kept making that noise
sounds like something may be wrong. Just to be sure, I will get the book out tonight and print the steps like they do in it.
You did have the key in the on position, like where it would be if you were driving it?
My tester stays on all the time after I cut the key off or when I have the key on acc. or in the off position.
