J302 Heads
J302 Heads
I have a set of ported j302 heads and would like to know your input on these heads. I keep hearing they are not good enough for my combo?
Stock short block
F-cam
Ported J302 Heads
Ported Saleen Vortech Intake
30# Injectors
Hooker Super Comp LTs
3" Exhaust
Erson 1.6rr
75mm TB
80mm Mass Air
T-5 with 4:10 Gears
Stock short block
F-cam
Ported J302 Heads
30# Injectors
3" Exhaust
Erson 1.6rr
75mm TB
80mm Mass Air
T-5 with 4:10 Gears
yah they're fine. you might want to downgrade injectors tho. 30#'s are a tad much, you won't be making enough power to support them I dont think.
some J302 specs:
1.94 intake and 1.60 exhaust valves (2.02 intake/1.60 on K302)
drilled and tapped for screw in rocker arm studs
accepts stock valve covers, intakes, and headers
exhaust flange has dual bolt pattern for added room for porting
combustion chambers are 58cc
intake port is 170cc
exhaust port is 60cc
uses Motorcraft AG series spark plugs
some J302 specs:
some J302 specs:
some J302 specs:
like matt said, injectors are unnecessarily big
So what if he only gets 300hp, there is a thing called tuning. You fix the amount of fuel the injector really squirts, it doesnt matter if its a 24# or 60#, it will shoot the same amount when the PW is adjusted correctly.
i agree with stinkinlincoln there isnt any need to buy new injectors when he will need a tune regardless. also that some rare parts in your build. j302 heads are some of the first aftermarket heads and then a saleen/vortech intake on top of that.
