rebuild time
rebuild time
found a tranny rebuild kit, its a kit by tremec, gonna order that its only 250$
now im looking for engine kits. do i need to put in new pistons?? or should mine be fine?
im not looking for a big power gain or anything, and ive not really got any signs of the engine going, just its 130,000 miles and i think its time to buy the stuff and do it in the winter.
im looking for a decent priced rebuild kit, anyone know of any good ones??
summit they are 500$ with pistons or like 200 without, i dont know what to do..someone help lol
RE: rebuild time
Summit make's great kits and if you do get one with piston's i would get forged.But there is really no reason to change the pistions unless they are showing wear or damage.So i would just overhaul it with new rings,rod bearings,main bearings,cam bearings and just hone the cylinders,unless you have some deep scratchs in the cylinder walls then new pistions is a must considering you will have to bore the block to remove them.
RE: rebuild time
get the pistons. im glad i did because m,y old ones were cracked [:@]. the increase in compression will give you a nice hp increase. they should by flycut so you can use a bigger cam as well. i used the summit kit and it worked great
RE: rebuild time
thanks both, good info
forged gives lower compression, but if im staying NA, i dont need low compression do i?? the hyper-whatchacallits, are cheaper, and give more compression = more power, right???
mkspeed, yours was it the kit form summit brand was umm.. speed pro i think?
RE: rebuild time
There's nothing wrong with replacing parts with age on them with new parts and sometimes just because a part "seems" to be good does not mean that it has hidden problems so for the money i would just go ahead and replace the pistions but that IMO and everyone has one.
