Christmas came early......what size injectors?
Old 07-11-2005, 08:29 AM
stanglx2002
stanglx2002's Avatar
Default RE: Christmas came early......what size injectors?
im not running 30's i have 24's in my car and it runs great so i would say 24's with the c&l 76mm kit
stanglx2002 is offline
Old 07-12-2005, 01:48 AM
cammedlx
cammedlx's Avatar
Just because you run a certain setup dosen't mean that everyone else should too,and 24's would be fine but even stock injectors can flow pretty close to that with bumped up fuel pressure so what's the point mine as well get 30's since you have the extra injector if you ever need it.
cammedlx is offline
Old 07-12-2005, 02:52 PM
vfast
I ♥ Acer
vfast's Avatar
the stock computer can handle 30's with no problem with the right MAF it's when you go to 42's problems arrive with the stock 'puter
vfast is offline
Old 07-12-2005, 04:08 PM
stanglx2002
ORIGINAL: vfast
then a tweecer and a pms would be good to fix the problem
Old 07-12-2005, 05:21 PM
MrFedEx503
MrFedEx503's Avatar
I know this sounds dumb whats with all the lbs talk i thought that was for like turbo or supercharge or sumthin like that... im osrry for being dumb
MrFedEx503 is offline
Old 07-12-2005, 08:02 PM
vfast
I ♥ Acer
vfast's Avatar
yes..
vfast is offline
Old 07-13-2005, 01:36 AM
fordguy17
fordguy17's Avatar
ORIGINAL: MrFedEx503
psi or pounds of boost is what your thinking of.
the bigger the rating for the injector the more fuel it can deliver.
fordguy17 is offline
mltdwn12
09-23-2015 08:54 AM
Demodulates
09-18-2015 11:14 AM
pimp2303
09-17-2015 08:45 PM
uedlose
09-10-2015 01:37 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Quick Reply: Christmas came early......what size injectors?
