any have this problem before
Old Sep 18, 2009 | 06:42 PM
lil_hulk87gt's Avatar
lil_hulk87gt
Default any have this problem before
ok i did a intake swap from a stock HO to the cobra intake. i have to get the car timed bad. But the last couple of days there has been smoke coming from the exhuast. yes i know smoke will come out from the car sitting for a bit and thats wht an exhaust dose. the thing thats is bothering me about it tho is it smells like fuel and kinda gives u a headach. i have thought possible head gasget but it dosent get any thinker wen you are driving its only at a idle it dose it. when you take off it give off a cloud like it was burning oil.. what the hell is going on.. and nother thing i have a fuel pressure gauge and today i was watchin it as i pushed the throttle and it was around 35-38psi but drops wen u hit the gas and it was like it just keept ging down is this normal? dose it have n e thing to day with the other problem or what? thanks for help
Old Sep 18, 2009 | 07:41 PM
AdderMk2's Avatar
AdderMk2
Banned
set your timing...
Old Sep 18, 2009 | 07:49 PM
Tony71502's Avatar
Tony71502
Yea basically. Did you MARK your dizzy/rotor before removing...
Old Sep 18, 2009 | 10:25 PM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
attention to detail when modding will help future pitfalls as such,, check for any vaccum leaks and set timing properly
Old Sep 18, 2009 | 11:23 PM
lil_hulk87gt
i pulled the distrubuter because i re placed with a brandy new one. so you guys think that by setting the timing right this smoke should go away.. ???? i had one guy tell me that the in take gasgets could have fallin a bit, is this tru?
Old Sep 18, 2009 | 11:33 PM
mjr46's Avatar
mjr46
it's possible you didn't get the intke gaskets seated properly and it is pulling in oil from the bottom side of the gaskets
Old Sep 19, 2009 | 12:51 AM
Tony71502's Avatar
Tony71502
It's basically standard measure that you do NOT use the cork gaskets on the front and back of the intake. Only use the gaskets between the intake and the cylinder heads. Use a heavy bead of silicone where the cork gaskets should be(front and back of block to lower intake mating surface).
Seanam
Oct 4, 2015 10:15 AM
mdj89
Sep 23, 2015 08:49 AM
kachuy10
Sep 22, 2015 01:27 PM
stangin1996gt
Sep 21, 2015 11:01 AM
Big Al's 03
Mach 1 Section
Sep 21, 2015 07:59 AM
