cleaning gt-40/explorer stuff?
Old Sep 20, 2009 | 07:46 PM
ptown87's Avatar
ptown87
Default cleaning gt-40/explorer stuff?
Just pulled upper and lower manifold off an explorer. how did you guys get those parts clean? The gaskets are baked on. What should I soak them in? thanks
Old Sep 21, 2009 | 03:49 PM
Bubba 95SN's Avatar
Bubba 95SN
Take to a machine shop well worth the couple of dollars. Will be clean no fuss.
Old Sep 21, 2009 | 10:54 PM
ptown87's Avatar
ptown87
I didn't think of that. Didn't know a machine shop would do that. I am thinking i will soak the old gaskets in Xylol or just gas, and hope it will then come off with a putty knife.
Old Sep 22, 2009 | 12:21 PM
justintx75's Avatar
justintx75
just becareful w/ alloy. i used degreaser and let it set for a while then hit it with the pressure washer and scraped off the rest.
also check w/ ure local machine shop to see what they offer
Old Sep 22, 2009 | 02:32 PM
Sidewayz6.0's Avatar
Sidewayz6.0
Most machine shops only charge $10-$15 to hot tank an intake like that.
It's not worth cleaning it yourself if you don't have a blast cabinet.
Old Sep 22, 2009 | 03:01 PM
mattdel's Avatar
mattdel
I use 3M Roloc polishing discs for all my gasket cleaning jobs. Work like a champ and they don't scratch, scuff, or maul even the cheapest aluminum.
Need an angled air die grinder for best use though. With a high enough RPM tool, you don't even have to pre-clean a big thick gasket, like an oil pan. Just let it come flying off as dust.
Old Sep 22, 2009 | 11:22 PM
nacanitihs's Avatar
nacanitihs
i used a rozor blade in a gasket scraper.. also if ur looking to clean it up a bit and paint it. i just used a wire wheel on a drill then used engine primer and silver engine paint. (high temp paint)
Old Sep 23, 2009 | 09:26 AM
ptown87's Avatar
ptown87
thanks for all the input. I am just gonna save myself the time and bring it to a machine shop. While there i should have them tap any holes needs. It's off a 96 and has internal EGR, so what else if anything needs to be tapped?
Old Sep 24, 2009 | 08:29 AM
ptown87's Avatar
ptown87
anyone?
Old Sep 24, 2009 | 04:32 PM
nacanitihs's Avatar
nacanitihs
the #5 runner for ur IAC sensor there should be a bung on the 96 one
