What Size Push Rods
Old Sep 26, 2009 | 08:13 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
here is the cam I have
http://www.summitracing.com/parts/CCA-35-600-8/
Old Sep 26, 2009 | 12:53 PM
sgarrelts01's Avatar
sgarrelts01
couldn't i just use this
http://www.summitracing.com/parts/CC...0/?image=large
Old Sep 26, 2009 | 02:54 PM
mjr46's Avatar
mjr46
Originally Posted by sgarrelts01
not unless you use a reduced base circle roller cam
Old Sep 26, 2009 | 03:31 PM
sgarrelts01
I found a Flat tappet cam with the correct firing order.
http://www.jegs.com/i/Comp+Cams/249/35-330-3/10002/-1#
Couldn't i just put this in, it will be the correct firing order, my computer will stop freaking out, and all should be fine?
Old Sep 26, 2009 | 03:50 PM
mjr46's Avatar
mjr46
you'd need to swap springs on heads and make sure valvetrain is adequate
Old Sep 26, 2009 | 04:01 PM
sgarrelts01
I have double springs with comp cam 1.6 rockers.
I went to Comp Cams website an looked at the specs, it says its for a 351, but Jegs an summit list it for a 302 also.
Also the Push rod length off the spec sheet says 8.700 that seems a little to big because i am using a 6.25 right now. Or is that push rod length for the 351 block.
Old Sep 26, 2009 | 05:38 PM
Liv2roc's Avatar
Liv2roc
this the the push rods for the retro fit cam http://www.summitracing.com/parts/CCA-7819-16/
if you want a flat tapped cam with the h.o. firing order just get a 351 cam it is the h.o. firing order. I put a roller cam in my 302 and got a 351 cam for the firing order.
Old Sep 26, 2009 | 05:58 PM
sgarrelts01
So your saying those 6.400 rods will work with that 351 cam i posted.
This one http://www.jegs.com/i/Comp+Cams/249/35-330-3/10002/-1#
Old Sep 26, 2009 | 06:15 PM
AdderMk2's Avatar
AdderMk2
Banned
why dont you just have the firing order changed in your ECM?
seems like that would make things a bit easier
Old Sep 26, 2009 | 06:18 PM
sgarrelts01
Because thats going to cost 6-800 dollars, and this cam with gaskets an stuff an even push rods is going to be under 300
