PCV/breather with s/c question
Here is the page out of my Procharger install manual. You can set yours up the same way. I mean, a centri is a centri basically.
Hope it helps ya. I also added a breather in place of my oil fill cap.
I almost through break-in on the new heads and cam, so I will be installing the #42 injectors and new mass air, then headed to the dyno to get it tuned for the new setup. I will discuss the PCV issue with the tuner and see what he says.
Thanks for the input.
That's a good idea. I wonder if I could just T off the exhaust connection to the smog pump and run my breather line to that. A little vacuum on the crankcase is probably good to keep seals from leaking. I might have to try a setup like that.
I have a question about the pcv on the back of the lower intake.. it has a hose leading off of it correct? and what does this hose look like b/c i can't seem to find it and i had just pulled it off lastnight.. or so i think.. the hose on the vacum tree saying either 8 or s or something the BIG hose.. that goes to the upper intake right? and the pcv hose goes to the upper intake as well? Can i just plug the pcv or leave it open or do i need to put it where it belongs?
its called a header evac kit.
as far as hooking it to the smog pump, ive heard of people doing that before but the pump usually clogs with oil and fails. never tried it myself tho
It's required here in CA if you want to be able to pass a smog test. Other states, I think you could disconnect it, as long as you plug the upper intake connections. Just run a hose from the PCV to the fenderwell or somewhere it can just vent to the atmosphere.
I have an update on this issue, so I thought I would share. The guy who tuned the car for me (who did an awesome job) told me to leave the PCV connected to the upper intake and connect the breather line from the valve cover to the pipe between my MAF sensor and the S/C. He said the 6 lbs of boost I was producing would not be too much for the PCV to handle (it should be held closed during boost) and placing the valve cover breather line before the S/C would create the needed suction on the breather line.
All is well with this setup. My seals aren't leaking oil now, and the car is running great.
AMAlexLazarus
AmericanMuscle.com
10-02-2015 08:06 AM
AMAlexLazarus
AmericanMuscle.com
10-01-2015 09:21 AM
treesloth
09-28-2015 07:03 AM
