Will 2.02 valves clear the pistons?
Old 10-16-2009, 12:05 PM
RyaNCSU1
RyaNCSU1's Avatar
Default Will 2.02 valves clear the pistons?
Looking at purchasing a set of Doug Herbert heads. 2.02 intake 1.60 exhaust. They say they will clear hte pistons but I want to make sure they will. Stock bottom end on an 87 5.0. Planning on running a cam with .510 - .550 lift tops. Havent decided yet.
I thought I had seen somewhere that only the TFS heads will clear a stock bottom using 2.02 valves.
RyaNCSU1 is offline
Old 10-16-2009, 06:31 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
most likely you'll run in to issues in the brow area, you'll need to verify ptv for sure
mjr46 is offline
Old 10-16-2009, 08:21 PM
RyaNCSU1
RyaNCSU1's Avatar
One feature that is good and bad in these heads is that they are 64cc chambers. Not great for compression but should give me more room for the valves? Guess I may stick to the smaller range in the cam as well to help with the clearance, maybe .520's somewhere.
RyaNCSU1 is offline
Old 10-16-2009, 08:43 PM
mjr46
mjr46's Avatar
chamber size has nothing to do with ptv clearance, nor does cam lift, it's all about cam timing
mjr46 is offline
Old 10-16-2009, 08:51 PM
RyaNCSU1
RyaNCSU1's Avatar
Would think having the larger chamber size would recess the valve that much more into the head? No? Im obviously just learning. By your statement I could even have the heads milled down to 60cc to help the comp. and have no impact on the vtp?
Maybe I will go that route and just go with a less aggressive cam with very little cam advance.
RyaNCSU1 is offline
Old 10-16-2009, 09:05 PM
mjr46
mjr46's Avatar
milling head will up compression, mill it to much and intake alignment issues will result, you want assurance, a custom cam can be designed to work with a stock bottom end and 2.02 valves
mjr46 is offline
Old 10-17-2009, 01:32 AM
redemption
redemption's Avatar
just get some playdoh putthe heads on with 2 rods in. crank it over 3 times slowing makng sure there is no binding, then take off heads and measure gap between playdoh were valve compressed, im trying to remeber. i think tis .090' and above you want
redemption is offline
Old 10-17-2009, 02:18 AM
w8less
w8less's Avatar
clay it up and check for yourself. every motor is different so even if it did clear on someone elses doesnt mean it will work for yours
w8less is offline
Old 10-17-2009, 06:55 AM
RyaNCSU1
RyaNCSU1's Avatar
thanks
RyaNCSU1 is offline
GimpyHSHS
19
12-19-2023 01:12 PM
mrtrodonet
09-19-2020 03:12 PM
ChampInSD
10-02-2015 04:55 AM
fastbackford351
10-01-2015 12:24 PM
Quick Reply: Will 2.02 valves clear the pistons?
