The motor is a Bennet 393 Stroker with a S-Trim @ 13 Lbs.. Normally it idles at 900 RPM consistently. After making a couple of high power runs, the idle ranges between 1500 and then settles back to a jumpee 650 to 950. I have cleaned the IAC, MAF etc. Before I made the full throttle runs it was idling perfect at 900. Any thoughts?
well at 13 lbs of boost. theres a good probability of blowing out a weak vacuum line or destroying a weak gasket. nowhere in particular to start, just get out a can of carb cleaner and trace all intake gaskets and vacuum lines.
