93 Cobra brake booster install help
Can anyone give me some advise on installing the 93 Cobra booster in a 92 coupe, I hear its a major pain in the butt. Some say you need to beat on the shock tower for room, others say you only need to enlarge the mounting holes, and some say you need to do both... Anyone know the real way? thanks
I just help a friend with his 92 GT do the M2300K install, which uses the 93 Cobra brake booster, and we ended up denting the backside of the strut tower to get it to fit.
When you try to put the brake booster studs through the firewall holes at an angle it hits the plastic piece and stops.
I have read about other option though (listed below).
(1) Remove/loosen Pedal box, insert booster, reinstall pedal box.
(2) Slightly denting (massaging) the backside of the strut tower.
(3) Take drill/Dremel and slot plastic piece from engine bay side. It is apparent which way you need to remove material from.
(4) Cut the studs down a little bit on the brake booster.
(5) Take the closed end of a wrench, say.... 1/2" wrench, and place it over a stud on the booster. If you hold the booster as if it were mounted to the firewall, you would want to bend the 4 studs gently and slightly to the left. By doing this it will allow you to slip the booster into the firewall without elongating any holes.
I'll assume and we all know assume means that at the dealerships they, remove/loosen Pedal box, insert booster, reinstall pedal box.
Faolan65
08-27-2015 06:40 AM
