Explorer Intake Install
Old Jul 17, 2005 | 06:16 PM
FoMoCo's Avatar
FoMoCo
Default Explorer Intake Install
MY '92 GT is ready for the explorer intake (upper and lower). Do I really need to drill and tap some holes? if so, which? Or can I just Install it without drilling anything? Another question, I know there is no power gains without the EGR, but can I just Remove it from my car anyway?
Old Jul 17, 2005 | 06:27 PM
Quik's Avatar
Quik
Default RE: Explorer Intake Install
youll see some gains but little from removing the egr. thats only if you do the total package.
for the GT40E intake. you will have to drill atleast one hole. its on the number 5 runner for the ACT. you dont really need to drill a hole for the return coolant unless you use the coolant going thru the EGR spacer
Old Jul 17, 2005 | 11:20 PM
birdman076's Avatar
birdman076
You do not have to drill the hole for the ACT sensor in the manifold, you can extend the wires and put it in the air intake tube between the MAF and the throttle body. Thats where mine is located and it has no adverse effects.
Old Jul 18, 2005 | 12:04 AM
badtzmaru's Avatar
badtzmaru
Here is a 1998 Ford Explorer lower and upper intake manifold in a 1994 GT.... very pleassed with the results and no drilling involved on mine, good luck.
[IMG]local://upfiles/10698/BC0236095910401BA797DD520435787B.jpg[/IMG]
Old Jul 18, 2005 | 12:11 AM
Quik's Avatar
Quik
some get bad readings from teh ACT being in the intake. you still have to drill and tap a spot for the sensor, so why not put it in the right spot
djbigskrilla
Sep 20, 2022 01:04 AM
cardsrus1
19
Sep 15, 2015 08:37 AM
SYNY5TER
Sep 2, 2015 01:35 AM
Sep 1, 2015 08:16 PM
kawiguy827
Sep 1, 2015 07:09 PM
