iac...?
iac...?
ive had idle issues for sum time now! it seems to me that the prob has sumn to do with the iac or what controls the iac...if i were to put the car in nutral after i accelerate my rpms would climb to about 3k and hold for about 3 sec b4 they drop very slowly back down to about 1200 or so... for those 3 sec or so i can hear air rushin through the iac untill the iac % comes back down.. what would cause my iac to react so slowly? from what imput does the computer get inorder to make canges to the iac %? could i be having a computer problem? ive tried the following things:
1. replaced iac with 2 new ones
2. adjusted tps to .98
3 unplugged the vehicle speed sensor ( thought i had sumn to do with tire size change)
4 done base idle reset after everything i tried
Is is using any oil? It will usually suck oil into the ports when leaking on the bottom.
Have you done a hard reset on the computer? unhooking battery and turning on the headlights to drain any capacitors in it then rehooking it up and letting it go thru the learning process again?
My 88 ran better after doing this.
this is not normal and it jus happen one day... before i did any mods to the car i jus hoped it would go away when i upgraded parts... but so far its still there .... if you heard and felt this you would agree.. i can feel this problem pushing the car when i approch a stop sign after a good acceleration....
p.s. i jus removed the iac and if i blow into one of the holes a small amout of air goes through it.. should this be 100% closed?
and no carbon n tb .... very clean
if im not using any oil my lower must not be leaking then right?
also, sorry for my lack of info, im on my mobile. do you have aftermarket tb, intake, heads, cam or maf?
