fuel problem
Old Dec 6, 2009 | 06:24 PM
generallee440's Avatar
generallee440
Default fuel problem
i got a 91 5.0 it runing reel rich and hard as hell to start got the timing set a 14 it a 306 with 19 pound injecters e303 cam 5 speed when you get is startrd it runs ok but you can smell fuel coming out of it some has unhooked the o2 sensers anything will help
Old Dec 6, 2009 | 10:48 PM
nitrous junkie's Avatar
nitrous junkie
I think I would start with simple stuff first like check your plugs and see if they are fouled maybe you got a bad plug wire or distributor cap or rotor.It could be missing a little.Is the check engine light on?You can use a jumper wire on the scanner plug under the hood to read the codes by the check engine light in the dash those cars have on board diagnostics.A chilton manual shows you how and what the codes mean.
SSRFUZZY
Members Other Vehicles
Jan 6, 2016 08:22 PM
StalkerGT
Sep 25, 2015 02:41 PM
zanemoseley
Sep 6, 2015 12:58 PM
5.0 kevo
Sep 3, 2015 06:24 PM
SYNY5TER
Sep 2, 2015 01:35 AM
