Carb swap
Old Dec 9, 2009 | 04:55 AM
sgarrelts01's Avatar
sgarrelts01
Default Carb swap
I decided today to swap over to carb to save some money.
I am not to familiar with what needs to be done. i know the fuel pressure is different, so i imagine i need a regulator to turn it down some.
other then that, what are some other things i am going to need.
Not to mention i don't know much about the intakes, what is a good intake for the 331 stroker, cam not picked yet. Looking to make about 400hp
Old Dec 9, 2009 | 08:48 AM
motorman524's Avatar
motorman524
MF Informant
swapping to carb will cost you about 1000$. is your car an auto?
Old Dec 9, 2009 | 08:55 AM
mjr46's Avatar
mjr46
D.R. THE PATHETIC DORK
I did it easily for under 500....and even less if you can source good used parts, Intake cost me 75.00, duraspark ignition and dizzy 125.00 and new carb cost me 245.00.....and fuel line and pump were under 50.00
Old Dec 9, 2009 | 08:59 AM
motorman524
MF Informant
^ did you buy used?
Old Dec 9, 2009 | 09:10 AM
sn95_331_GT_ yellow's Avatar
sn95_331_GT_ yellow
mjr, are you using the mechanical style pump on the timing cover or an in line? im trying to get a feel of which way to go on my car too...
Old Dec 9, 2009 | 09:25 AM
sgarrelts01
Stick, and why is it going to cost me about 1000.
I need a Distributor, MSD and intake.
Can just use a fuel reg to get it down to the pressure needed, not the best way but doable.
Its cheaper then spending 300 on new injectors, 300 on new MAF, new intake, 600 for a tune, not to mention whatever else comes along.
But i guess if i did get all knew top of the line stuff a 1000 would be about right.
What kind of intake is good, i don't know much about carb intakes. What is a carb intake that would be on par with lets say the Trick Flow track heat.
Old Dec 9, 2009 | 11:00 AM
mjr46's Avatar
mjr46
on my 92, I'm using a mech pump on the timing cover, but the donar car was a 85 for this 4 cyl proj so I went with what was there, for an efi ride to carb conversion, elec pump is the way to go, I went with a holley blue on my 85
Old Dec 9, 2009 | 11:02 AM
mjr46's Avatar
mjr46
^ did you buy used?
only the intake....duraspark stuff was all bought at napa and the edl 600 carb was bought new as was the pump and line
bradleyb
Nov 27, 2015 07:50 PM
Bokeo
Oct 10, 2015 08:28 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
bradleyb
California Regional Chapter
Oct 1, 2015 01:02 AM
guitarman376
Sep 30, 2015 05:54 PM
