if the ignition switch wire is bad then it would not even crank right??? cause i can get it to crank just just fine sometimes and other times very slow and then just a click
when i start the car the battery goes from 13.45 to 10.99
theres a lot of resistance somewhere. how long has it been since you have changed or even looked at the battery cables? what do the battery cable ends look like?
all of the cables are less than 6 months old the battery ends look like new no corrosion
the thing that gets me is that it only dose it sometimes not all the time i would put my life on it that i could go out to the garage and it would start and run great
Originally Posted by 1988TTOP
(Post 6734196)
yea i took the starter out and had it tested tested good so i put it back in the starter solenoid seems like it is ground good its tight and everything is clean behind it
