As opposed to going with a 31 Spline axles and an Eaton unit, I just decided to replace the rear end clutches and see where that gets me. I just figured spending $80 bucks and seeing what happens is worth a shot, as opposed to spending $700.
Any thoughts on how long that should do the trick with eliminating the one wheel burnouts and what's the downside going one way verse the other?
Just replace the clutches with the carbon fibers and forget about it. How long they last depends on mileage, and how you drive it. It doesn't appear that your car is highly modified, the new clutches will work fine.
Ooops, I missed the fact that you have a power adder, but the clutch replacement will still work fine with your mods, especially if you set them up on the "tight" side.
That was the plan and I don't put too many miles on the car or blow it out at the track, so I'm hoping this will do the trick for at least a little while.
I'm not a fan of the auburn units cause I believe they are non rebuildable......
i did not know that. definitely want to stay away from any rear end thats not rebuildable because nothing lasts forever and thats one area of the car that takes a lot of abuse
